$383.90
Article number: 023-06-02
The latest 180 hub generation enhances DT Swiss' top-of-the-line hub. Ratchet EXP system boosts bearing lifetime, stiffness by 15%, and energy transfer with 36 teeth. Tool-free disassembly and lightweight design make maintenance a breeze. Paired with SINC ceramic bearings, these hubs offer unparalleled performance.
WHEEL BUILDING
 Compare Compare
  180 240
 Weight ~95g ~110g / 118g
 Spoke Holes 28h 28h
 Axle Standard T/A 15 x 110 T/A 15 x 110
 Bearing Size Ceramic 6803 - (2) 1728 - (2)
 Brake Interface Centerlock Centerlock / 6-bolt
--Wheel Building Dimensions--
  LEFT RIGHT
 Flange Diameter 34.5 mm 34 mm
 Center to Flange 26.4 mm 39.8 mm
 Spoke Hole Offset 1.05 mm 0.1 mm
 Spoke Hole Diameter 2.5 mm
