DT Swiss 240 EXP Road Front Rim Brake Hub
$229.90
$195.16
* Unit price: $195.16 /
Article number: 023-06-03
With the latest generation of the 240 hub, the strengths of DT Swiss' legendary hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The latest version of the end caps simplifies the tool-free disassembly and makes maintenance easier.
Covered by a 2 year warranty against manufacturing and material defects, 240 EXP hubs offer some of the best performance in the industry.
WHEEL BUILDING
Trust a skilled wheel builder for DT Swiss hub wheels. We offer expert service and rim/spoke advice. Contact us for custom wheels.
  Straight-Pull J-Bend
 Weight ~107g ~115g
 Bearing Size Stainless - 1526 (2)
 Spoke Holes 20 20 / 24
 Axle Standard 5 mm x 100 mm
 Brake Interface Rim Brake Only
--Wheel Building Dimensions--
 Flange Diameter Left 30.6 43.5
 Flange Diameter Right 30.6 43.5
 Center to Left Flange 38.3 37.5
 Center to Right Flange 38.3 37.5
 Spoke Hole Offset L / R 0.0 / 0.0
 Spoke Hole Diameter 2.5 mm 2.4 mm
