$229.90
Article number: 010-03-07
With the latest generation of the 240 hub, the strengths of DT Swiss' legendary hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The latest version of the end caps simplifies the tool-free disassembly and makes maintenance easier.
Covered by a 2 year warranty against manufacturing and material defects, 240 EXP hubs offer some of the best performance in the industry.
WHEEL BUILDING
  24 hole 28 hole
 Weight ~104g ~105g ~114g
 Axle Standard 12 x 100 15 x 100
 Brake Interface Centerlock Centerlock 6-bolt
 Bearing Size 1526 - (2) 1728 - (2)
 Flange Diameter Left 37.2 35.5
 Flange Diameter Right 37 35.5
 Center to Left Flange 22.1 21.6
 Center to Right Flange 35.2 34.8
 Spoke Hole Offset L / R 1.4 / 0.4 1.9 / 0.2
 Spoke Hole Diameter 2.5 mm
