DT Swiss 350 J-Bend Boost Disc Rear Hub
DT Swiss updates rear hubs for Boost 148, with 240-inspired design for performance. The DT 350 hub combines advantages with affordability, thanks to streamlined production and overseas facilities. Easy servicing with standard bearings and hub flanges. Opt for the 54-tooth ratchet for quick engagement. Rapid Drive rings boost performance with few trade-offs.
WHEEL BUILDING
Trust a skilled wheelbuilder for DT Swiss hub wheels. Please contact us for expert service and rim/spoke advice.
| Centerlock | 6-Bolt | |
| Weight | ~249g | ~277g |
| Bearing Size | 6902 - (2) | |
| Spoke Holes | 28 / 32 | |
| Axle Standard | 12 x 148mm Boost | |
| Freehub Body Options | Shimano 10/11 / SRAM XD / Micro Spline | |
| Freehub System | 36t SL Ratchet | |
| --Wheel Building Dimensions-- | ||
| Flange Diameter Left | 47 mm | 60 mm |
| Flange Diameter Right | 47 mm | 50.5 mm |
| Center to Left Flange | 36 mm | 36.6 mm |
| Center to Right Flange | 23.2 mm | 23.4 mm |
| Spoke Hole Diameter | 2.6 mm | |
