$112.90
Article number: 010-03-03
The DT Swiss 350 Road Front Hub delivers a balance of lightweight design, durability, and easy serviceability for road and all-road applications. Its redesigned shell and axle draw from the proven DT 240 platform, offering dependable performance at a more accessible price point. Available in J-Bend or Straight-Pull spoke configurations, it uses standard sealed cartridge bearings for straightforward maintenance and is compatible with optional ceramic bearing upgrades for reduced friction. Built for rim-brake systems, it’s a versatile choice for custom wheel builds and long-term reliability.
  • Lightweight, precision-machined hub shell
  • J-Bend and Straight-Pull spoke compatibility
  • Optional ceramic bearing upgrade
  • Rim-brake only, 5 mm × 100 mm axle standard
  • Tool-friendly maintenance design
  • 2-year manufacturer warranty
WHEEL BUILDING
  J-Bend Straight-Pull
 Weight ~146g ~114g
 Spoke Holes 20h / 24h / 32h 20h
 Axle Standard 5 mm x 100 mm
 Bearings Size 6902 - (2)
 Brake Interface Rim Brake Only
 Flange Diameter Left 39 mm 26.15 mm
 Flange Diameter Right 39 mm 26.15 mm
 Center to Left Flange 37.4 mm 37.8 mm
 Center to Right Flange 37.4 mm 37.8 mm
 Spoke Hole Diameter 2.6 mm 2.5 mm
Pair your front hub with the matching 350 Road Rear Hub for a complete build. For a lighter alternative, consider the 240 Road Front Hub. Upgrade performance with a Ceramic Bearings or browse Wheelbuilding Tools for maintenance.
