ENVE In-Route Aero Carbon Handlebar
Article number: | ENVE-5 |
The aerodynamically optimized Aero In-Route carbon road bar allows you to reduce drag and go faster. Through careful shaping and minimizing frontal surface area, it's the ideal bar for road cyclists and triathletes seeking maximum aero benefits. ENVE's unique compact geometry offers thoughtful ergonomics while remaining compatible with both analog and electric drivetrains. The updated IN-Route design ensures compatibility with most internally routed front ends. Made from lightweight yet durable carbon fiber, the SES Aero Handlebar features integrated bar end plugs and is available in multiple widths to dial in your ideal fit. Designed for use with the In-Route Aero Stem for clean aesthetics and airflow.
Depending on your riding style, it may be advisable to select a wider handlebar than you would normally ride.
Width C(enter) - C(enter) | 40 cm | 42 cm | 44 cm | 46 cm |
Hoods | 35 cm | 37 cm | 39 cm | 41 cm |
Drops | 40 cm | 42 cm | 44 cm | 46 cm |
Weight | ~266g | ~270g | ~280g | ~290g |
Reach | 79 mm | |||
Drop | 127 mm | |||
Internal Di2 Routing | Yes | |||
Clamp Diameter | 31.8 mm | |||
Material | Carbon | |||
Clamp Area | 48 mm | |||
Torque Specs | Faceplate | Shift / Brake Clamp | ||
5.5Nm | 6 - 8Nm |
