$975.00
Article number: 15-01-03
The versatile ENVE G27 gravel rim expands possibilities for drop bar adventures, clearing tires from 42 mm gravel to 2.25” MTB tires for confident riding on rugged singletrack. ENVE's patented Wide Hookless Bead rim design dramatically reduces pinch flats when running low tire pressures off-road. Durable yet lightweight at 320g, the tubeless-ready G27 maintains secure tire seal thanks to the molded bead lock, enabling true mixed-surface riding.
Select our premium wheel-building service for the precise assembly of ENVE rims. Gain valuable recommendations on hub and spoke selection. Reach out to us for personalized support.
DIMENSION
 Weight ~320g
 Rim Depth 25 mm
 External Width 35.5 mm
 Internal Width 27 mm
 ERD 571 mm
 Hole Count 24 Hole
 Bead Type Hookless
 Tire Type Tubeless Ready
 Suitable Tire Widths 650b x 42 - 57 mm | 27.5 x 1.65" - 2.25"
INCLUDED - G27 Tubeless Kit
30.5 mm Tubeless Tape
47 mm Tubeless Valves
Brass Nipples
