ENVE Replacement Freehubs
Article number: | 18-02-05 |
Replacement ENVE Alloy or 2nd Gen. Carbon hub freehub bodies. Quick Release and Thru-Axle end caps are sold separately, If you need the end caps see the chart below for the links to the correct end caps for your needs.
Freehub | Centerlock Thru Axle Kit | Centerlock Quick Release Kit | Road Quick Release Kit |
Shimano | Freehub - 100-4001-306 | Freehub - 100-4001-306 | Freehub - 100-4001-306 |
Drive Side Cap | End Cap - 100-4001-415 | End Cap - 100-4001-412 | End Cap - 100-4001-412 |
Campagnolo N3W | Freehub - 100-4001-450 | Freehub - 100-4001-450 | Freehub - 100-4001-450 |
End Cap - Quick Release & Thru Axle Drive Side End Cap included | |||
SRAM XDR | Freehub - 100-4001-308 | Freehub - 100-4001-308 | Freehub - 100-4001-308 |
End Cap - 100-4001-416 | End Cap - 100-4001-411 | End Cap - 100-4001-411 | |
Shimano Light | Freehub - 100-4001-316 | Freehub - 100-4001-316 | Freehub - 100-4001-316 |
End Cap - 100-4001-415 | End Cap - 100-4001-412 | End Cap - 100-4001-412 | |
Campagnolo | Freehub - 100-4001-307 | Freehub - 100-4001-307 | Freehub - 100-4001-307 |
Non-Drive Side End Caps | Centerlock Thru Axle | Centerlock Quick Release | Road Quick Release |
100-4001-422 | 100-4001-358 | Carbon Hub | |
100-4001-380 | 100-4001-412 | ||
Alloy Hub | |||
100-4001-413 |
Shimano HG Freehub
Compatible with Shimano HyperGlide (HG) 8 - 12 speed cassettes.
Shimano HG Light Freehub
Lightweight Shimano Hyperglide (HG) Freehub Option, spec’d on ENVE 2nd generation carbon hubs. Compatible with Shimano HyperGlide (HG) 8 - 12 speed cassettes.
SRAM XDR Freehub
Compatible with XD (With 1.8mm cassette spacer) and XDR 11 and 12 speed specific cassettes.
Campagnolo Freehub
Compatible with Campagnolo 8 - 12 speed specific cassettes.
Campagnolo N3W Freehub
Compatible with Campagnolo 13 speed specific cassettes. QR and Thru-Axle End caps included.
