ENVE Seatpost Replacement Hardware
Article number: | 18-04-04 |
Availability: | In stock (10) |
These full replacement saddle rail clamp kits for Enve's carbon seatposts include everything needed to replace lost or damaged hardware. They are available in either first generation single bolt, or second generation twin bolt. Single bolt kits include 7mm adapters for round, alloy saddle rails and 7x10mm adapters for oval carbon saddle rails. Twin bolt kits include 7mm adapters for round, alloy saddle rails and 7x9mm adapters for oval carbon saddle rails.
Kit Contents (Single Bolt Kit) | Upper and Lower Clamp, Standard Rail Wedge/Bolt, Oversize Rail Wedge/Bolt |
Kit Contents (Twin Bolt Kit) | Standard Rail Upper Clamp, Oversize Rail Upper Clamp, Lower Clamp, Wedges and Bolts |
Weight (Single Bolt Kit) | 50 - 52 grams |
Weight (Twin Bolt Kit) | 61 - 66 grams |
