$1,095.00
Article number: 15-
 ENVE's SES 4.5 Rim is designed for speed and confidence across various terrains. Its 25mm internal rim width ensures precise handling, particularly on technical courses, while optimizing road tubeless performance minimizes the risk of pinch flats. This aerodynamic carbon fiber rim is a game-changer for fast-paced rides, offering unmatched reliability and efficiency.
Trust experienced wheel builders for top-notch assembly of ENVE rims. Opt for our expert wheel-building service and receive valuable advice on hub and spoke selection. Contact us for personalized assistance.
 Model SES 4.5 Legacy 3.4 AR Legacy 4.5 AR
  Front Rear Front Rear Front Rear
 Rim Depth 49 mm 55 mm 39 mm 43 mm 49 mm 55 mm
 External Width 32 mm 32 mm 31 mm 30.5 mm
 Internal Width 25 mm 25 mm 25 mm
 Weight ~425g ~435g ~387g ~394g ~440g ~450g
SES 4.5 Specifications Front Rear
ERD
558 547
Hole Count 24 hole
Bead Type Hookless
Tire Type Tubeless Ready
Minimum Tire Size 700 x 27
Valve Stem Length 66 mm 72 mm
Tubeless Tape Width 29 mm
TIRE COMPATIBILITY
INCLUDED
Tubeless Kit - Tape / Valves (4.5)
Brass Nipples
Valve Extenders (55 mm)
