ENVE SES Tubeless Race Day Tire
Article number: | 006-01-05 |
The ENVE SES Tubeless Race Day Tire is engineered for maximum speed when every second counts. Prioritizing aero efficiency and lightweight design, it delivers up to an 8.5‑watt reduction in rolling resistance and sheds as much as 75 g per tire compared to the standard SES. Constructed with a novel, hyper-efficient nylon casing and nano‑particle infused rubber, it achieves exceptional performance with a minimal and surprisingly robust build—no puncture belt needed, yet offering puncture resistance on par with belt-equipped models—and delivers superior wet grip.
Featuring a nano-technology enhanced rubber compound, novel casing construction, and our aerodynamically optimized SES tread pattern and shape - these tubeless tires deliver. As a pure performance tire, the SES Race Day prioritizes speed over puncture resistance and longevity.
- Ultra-light tubeless road tire designed for race-day performance
- Up to 8.5 watt improvement in rolling resistance vs. standard SES
- Up to 75 g weight saving per tire
- Innovative hyper-efficient nylon casing, similar in concept to high-performance carbon layups
- Nano‑infused rubber compound (e.g. “graphene-like”) for speed and durability
- Surprising puncture resistance despite lacking a conventional puncture belt
- Excellent wet-weather grip—the best edge grip tested to date
TIRE SIZE | 27 mm | 29 mm |
Compatible With | All ENVE Wheelsets | |
Weight | ~195g | ~210g |
Internal Rim Width | Inflated Width on Suggested Rim Pairing | |
19 mm | 27 mm | 28 mm |
21 mm | 28 mm | 29 mm |
23 mm | 29 mm | 30 mm |
25 mm | 30 mm | 31 mm |
