Extralite BlackLock Rear Thru Axle
| Article number: | 010-01-02 |
With the rising popularity of thru axle designs being used by nearly every major fork and frame manufacturer, companies like Extralite have immediately filled in the niche for quality performance tuned parts that many discerning cyclists desire. With this in mind, Extralite has produced the BlackLock, a surprisingly lightweight thru axle skewer. Utilizing a unique externally tapered surface and precise dimensioning, Extralite is capable of shaving as many grams as possible while still maintaining a sturdy design that’s tough enough to withstand the abuse of a typical mountain bike ride. To ensure proper installation that’s as smooth as possible, each BlackLock comes with a self lubricating brass washer that is designed to reduce friction between the skewer and frame/fork.
INSTALLATION
Each BlackLock skewer is simply installed using a 6 mm allen wrench at a torque rating of 10 Nm. It is highly recommended that the threads are greased prior to installation to ensure a proper torque rating.
| Model | Interface | Length | Compatibility | Length | Weight |
| X-12 / Syntace (12 x 1.0 mm) | |||||
| 12.2 | Tapered | 161 mm | Specialized | 17 mm | ~29g |
| 12.2-B* | Tapered | 166 mm | Specialized Boost | 17 mm | ~30g |
| 12.4-B* | Flat | 172 mm | Scott Boost pre-'22 | 17 mm | ~29g |
| 12.4-C | Flat | 178 mm | Scott Spark '22+ | 13.5 mm | ~30g |
| 12.6 | Flat | 185 mm | SRAM UDH | 15 mm | ~31g |
| E-Thru (12 x 1.5 mm) | |||||
| 12.1 | Flat | 172 mm | E-Thru | 18 mm | ~29g |
| 12.1-B* | Flat | 178 mm | E-Thru Boost | 18 mm | ~31g |
| 12.4-RA | Flat | 158 mm | Scott Road pre-'20 | 13 mm | ~27g |
| 12.4-RB | Flat | 163 mm | Giant Road | 13 mm | ~28g |
| 12.4-RC | Flat | 168 mm | Scott Road '20+ | 13 mm | ~29g |
| Maxle (12 x 1.75 mm) | |||||
| 12.3 | Flat | 176 mm | Maxle | 19 mm | ~30g |
| 12.3-B* | Flat | 182 mm | Maxle Boost | 20 mm | ~30g |
| 12.4-RE | Flat | 166 mm | Trek Emonda | 19 mm | ~28g |
| Material | 7075 T6 Aluminum | ||||
| Tool Fitting | 6 mm Hex | ||||
| Hub Compatibility | T/A 12 x 142 | T/A 12 x 148* | ||||
| Recommended Torque | 8 - 10Nm | ||||
