FWB Ceramic Bottom Bracket for DUB Spindles
Unlock the full potential of your drivetrain with the Fair Wheel Bikes Ceramic Bottom Bracket, developed in collaboration with HSCeramics—one of the industry’s most respected names in ultra-low-friction bearing technology. Purpose-built for SRAM DUB spindles and engineered to fit the most widely used bottom bracket standards, this BB delivers world-class efficiency, durability, and precision.
Ultra-Low Friction Performance
At the heart of each unit are high-grade ceramic bearings manufactured to exacting tolerances by HSCeramics. These bearings spin exceptionally smooth with minimal resistance, helping you conserve watts whether you’re powering through a climb or chasing marginal gains in a time trial.
Advanced Sealing & Longevity
Thanks to HSCeramics proven sealing systems and Fair Wheel’s refined shell design, this bottom bracket offers outstanding protection from contaminants. You get increased lifespan, reduced maintenance needs, and consistent performance in all riding conditions—from gravel grit to monsoon rain.
Engineered for Perfect Fit
Available in T47, PF30, BB86, and BB386 configurations, each model is machined to ensure precise alignment and quiet, creak-free operation. The combination of high-quality materials, tight tolerances, and meticulous assembly gives you a bottom bracket you can trust for thousands of miles.
Key Features
- Designed specifically for SRAM DUB (28.99 mm) spindles
- Premium HSCeramics bearings for superior smoothness and efficiency
- Multiple standards supported: T47, PF30, BB86, BB386
- Enhanced sealing for longevity and reduced maintenance
- CNC-machined shells for perfect fit and creak-free performance
Ideal for road, gravel, and high-performance MTB applications
If you’re looking to elevate your drivetrain with world-class bearing performance and uncompromising build quality, the Fair Wheel Bikes x HSCeramics Bottom Bracket is the upgrade that delivers every time.
| BB Standard | T47-In | T47-Ex | PF30 | BB386 | BSA |
| Spindle | 29 mm | ||||
| Weight | ~ 92g | ~ 95.8g | ~ 114.1g | ~ 95.3g | ~ 88.3g |
| Shell I.D. | 47mm | 47mm | 46mm | 41mm | 41mm |
| Installation Tool | Included | T47 16 Notch | Bearing Press | Bearing Press | Bearing Press |
| Material | Delrin Thermoplastic - Si3N4 Ceramic Hybrid - Aluminum | ||||
