$25.00
$20.00
* Unit price: $20.00 /
Article number: 018-05-04
Each set includes left and right hoods, meticulously designed for Campagnolo 10-speed levers.
INSTALLATION
 Compatibility Campagnolo 10-speed Shift Levers
 Weight ~43g (pair)
