Far and Near Front Thru Axle
Article number: | 14-02-03 |
Far and Near has a plethora of parts to color coordinate every aspect of your next build. Their simple no-nonsense approach to bike components crafts pieces that are as dependable as they are elegant. Creating a low profile thru axle in the two most common designs (Fox and Rock Shox) Far and Near has produced an axle you can depend on. Built from 7075 Aluminum and anodized to a rich hue these axles feature a robust head and deep 6mm allen wrench grooves assuring that once installed it will stay put. Tapered in the center to reduce weight Far and Near have shaved grams while maintaining an axle that is strong enough withstand the most strenuous riding conditions.
Check out our blog for better info about which thru axle to use | ||||||
Model | Hub Compatibility | Interface | Length | Thread Pitch | Thread Length | Weight |
12mm Rock Shox Road | TA 12 x 100 | Flat | 119 mm | 12 x 1.5 mm | 13.5 mm | ~29g |
Fox | TA 15 x 100 | Flat | 146 mm | 14 x 1.5 mm | 13 mm | ~37g |
Fox Boost | TA 15 x 110 Boost | Flat | 155 mm | 14 x 1.5 mm | 13 mm | ~39g |
Rock Shox | TA 15 x 100 | Flat | 147 mm | 15 x 1.5 mm | 11 mm | ~37g |
Rock Shox Boost | TA 15 x 110 Boost | Flat | 155 mm | 15 x 1.5 mm | 11 mm | ~39g |
Material | 7075 Aluminum | |||||
Tool Fitting | 6mm hex | |||||
Recommended Torque | Max 10Nm |
