$28.00
Article number: 023-06-06
The FSA SL Angular Contact Bearing is a great example of an inexpensive way to shed a couple grams from your vital moving parts. Substituting an aluminum cup for the bulky outer race, FSA has dropped over 25% of the weight from a traditional all steel bearing. This significantly lighter bearing still has two steel races and ball bearings, they have just been put on a serious diet. To slim them down FSA had to eliminate all superfluous material, without the bulky steel outer race you get a bearing that performs flawlessly at fighting weight. Since a headset sees little rotation throughout its life it is a perfect candidate for a bit of gram shaving. If you're trying to build the lightest bike possible, a set of FSA SL Headset Bearings are the perfect choice for your next project.
Bearing Fits Angle (I.D. x O.D. x Height) Weights
 MR054R 1-1/8" 36°x45° 30 x 41 x 6.5 mm ~13.0g
 MR042R 1-1/8" 45°x45° 30 x 42 x 8 mm ~14.1g
 MR082R 1-1/4" 45°x45° 34 x 47 x 7 mm ~17.6g
 MR110R 1-1/2" 36°x45° 52 x 40 x 8 mm ~21.0g
 MR128R 1-1/2" 45°x45° 52 x 40 x 7 mm ~22.5g
