FSA SL Headset Bearing
| Article number: | 023-06-06 |
The FSA SL Angular Contact Bearing is a great example of an inexpensive way to shed a couple grams from your vital moving parts. Substituting an aluminum cup for the bulky outer race, FSA has dropped over 25% of the weight from a traditional all steel bearing. This significantly lighter bearing still has two steel races and ball bearings, they have just been put on a serious diet. To slim them down FSA had to eliminate all superfluous material, without the bulky steel outer race you get a bearing that performs flawlessly at fighting weight. Since a headset sees little rotation throughout its life it is a perfect candidate for a bit of gram shaving. If you're trying to build the lightest bike possible, a set of FSA SL Headset Bearings are the perfect choice for your next project.
| Bearing | Fits | Angle | (I.D. x O.D. x Height) | Weights |
| MR054R | 1-1/8" | 36°x45° | 30 x 41 x 6.5 mm | ~13.0g |
| MR042R | 1-1/8" | 45°x45° | 30 x 42 x 8 mm | ~14.1g |
| MR082R | 1-1/4" | 45°x45° | 34 x 47 x 7 mm | ~17.6g |
| MR110R | 1-1/2" | 36°x45° | 52 x 40 x 8 mm | ~21.0g |
| MR128R | 1-1/2" | 45°x45° | 52 x 40 x 7 mm | ~22.5g |
