$30.00
* Unit price: $30.00 /
Article number: 022-02-03
KCNC's series of precision-machined 6061 aluminum thru axles present an excellent low-cost replacement option for frame manufacturer's stock thru axles. Compared to KCNC's 7075 Low Profile Thru Axles, these are about twice the weight, but half the price. As such, the 6061 thru axles are an excellent option for replacing lost or damaged thru axles, or as an upgrade to a lever-free design. Installation and removal are accomplished with a 6mm hex wrench, with tool fittings on either end of the thru axle for maximum convenience.
Compatibility
KCNC 6061 Rear thru axles are available to fit 12 x 142 and 12 x 148  frames, in either RockShox Maxle or E-Thru standards.
For complete sizing details on all of our thru axles please look HERE or give us a call.
 E-THRU Head Length Thread Pitch Weight
 167 mm* Flat 167 mm 19 mm 12 x 1.5 mm ~44g
 172 mm* Flat 172 mm 19 mm 12 x 1.5 mm ~44g
 177 mm* Flat 177 mm 19 mm 12 x 1.5 mm ~44g
 MAXLE Head Length Thread Pitch Weight
 180 mm* Flat 180 mm 22 mm 12 x 1.75 mm ~47g
 177 mm* Flat 188 mm 22 mm 12 x 1.75 mm ~47g
 Material 6061 Aluminum
 Tool Fitting 6 mm Hex
 Hub Compatibility T/A 12 x 148* (Boost)
 Recommended Torque 10Nm
