Lizard Skins DSP 4.6 Bar Tape
| Article number: | 004-01-01 |
This 4.6mm version is the thickest, most comfortable of the three DSP tape options. This version is recommended for gravel, cyclocross, and all-road disciples where a thicker tape can provide added comfort on rough terrain. Additionally, riders who enjoy longer rides or who simply desire slightly more cushion at the handlebars will benefit from this 4.6mm tape.
Includes two rolls of tape, color-matched bar plugs, clamp cover strips, and premium finishing strips.
| Weight per Roll | 43 grams |
| Weight per 100cm | 18.6 grams |
| Weight, Bar Plugs (pair) | 19 grams |
| Roll Length | 231 cm |
| Thickness (measured) | 4.6 mm |
| Material | Polymer |
