Mcfk Carbon Road Handlebar
$405.00
$344.25
* Unit price: $344.25 /
Article number: 023-03-01
Germany-based MCFK has been making a name for themselves producing high quality handmade carbon components. Their first handlebar uses the 31.8mm diameter compatible with most modern stems. Many co-molded pieces of UD, 1k and 3k carbon fiber are a masterfully crafted into a comfortable ergonomic shape. The tops feature several degrees of backsweep for relief on the wrists. A channel on the underside routes the cables cleanly and maintains a comfortable round profile under the tape. The transition out to the hoods is very flat to allow a long perch with many comfortable positions. The drops are relatively shallow at 130mm with a long graceful curve that flares out a few degrees. These bars are very stiff with a 100kg weight limit. Please use a calibrated torque wrench and follow the manufacturer's guidelines for maximum torque settings.
 Size C to C Hoods C to C Drops Weight
 38 cm 38 cm 41 cm ~151g
 40 cm 40 cm 43 cm ~154g
 42 cm 42 cm 45 cm ~156g
 40 cm 44 cm 47 cm ~159g
 Reach 77 mm
 Drop 130 mm
 ICR Compatible No
 Back Sweep
 Drop Angle
 Clamp Diameter 31.8 mm
 Rider Weight Limit 100kg
