Mcfk Leather Carbon Saddle
Article number: | 023-05-06 |
Focused on comfort and durability, Mcfk’s Leather Saddle is incredibly light and possesses a unique aesthetic. These sleek saddles are made entirely of carbon except for a thin layer of padding and leather. The thin flexible carbon shell provides a solid platform that offers ride all day comfort at race day weight. The thin layer of padding and leather wrapping provides a small amount of cushion and friction to prevent sliding when in an extremely aggressive position. The wide nose and smooth transition from front to back offer increased real estate for longer rides or varied terrain. The ovalized carbon rails are bonded directly to the saddle shell and feature an optimised fiber orientation to maintain strength over the entire clamping area. This design allows for full utilization of the rail length translating into more adjustability. Available in black and white, the Mcfk Leather Saddle offers riders an ultralight option without sacrificing comfort.
Each Mcfk component is 100% manufactured in Germany for the utmost in quality control and feature a 2 year warranty against defects in materials and workmanship.
As with any carbon component, care should be taken to ensure proper assembly. To avoid localized damage to the carbon rails, the seatpost's rail clamps should be inspected prior to installation. The rail clamps' edges should have smooth transitions where they contact the rails. Often, rail clamps can be modified through careful filing to improve this interface. The careful application of bolt torque is also an important consideration. Never go beyond manufacturer's specifications, and use a torque wrench whenever possible.
Width | 130 mm | 135 mm | 140 mm |
Weight | ~101g | ~103g | ~105g |
Construction | Full Carbon Fiber with Leather Cover | ||
Length | 260 mm | ||
Rail Diameter | 7 x 9 mm oval | ||
Use | Road, Cross country, Cyclocross | ||
Rider Weight Limit | 100 kgs (220 lbs) |
Weights can fluctuate by +/- 5%
