Praxis Replacement Bolt / Extractor
| Article number: | 015-03-01 |
The Praxis M30 or M24 Main Bolt & Self-Extractor kits keep your crank arms spinning smoothly for the long haul. These all-in-one solution combine a durable chromoly steel main bolt with an integrated self-extractor. Simply use an 8mm hex wrench to install the bolt and securely fasten your M30 or M24 crank arm. When service is needed, the self-extractor design allows easy crank arm removal using a cassette tool.
| Crankarms | M30 | M24 |
| Bolt Size | M16 x 1.0 x 16 mm | M15 x 1.0 x 15 mm |
| Usage | Praxis M30 & SL eCranks | Praxis M24 & eCranks |
| Torque | 48 - 52Nm | |
| Tools | 8 mm Allen | |
