Schwalbe Pro One Addix TLE Tubeless Ready Tire
| Article number: | 006-02-01 |
A truly thrilling ride. It's fast. It’s reliable. It’s light. The patented MicroSkin construction makes this all possible, ~70g less weight, 15% less rolling resistance and improved cut resistance all around. This is the absolute top model from Schwalbe!
You can also use the Schwalbe Pro One with a normal tube, but its true strengths are experienced only in tubeless form.
| Size | Weight | Pressure Range |
| 700 x 25c | ~245g | 70-110 psi (5.0-7.5 bar) |
| 700 x 28c | ~270g | 60-95 psi (4.0-6.5 bar) |
| 700 x 30c | ~295g | 45-80 psi (3.0-5.5 bar) |
| Compatibility | Tubeless Clincher | |
| Intended Use | Road | |
