SRAM Centerline X 6-Bolt Disc Brake Rotor w/Ti Bolts
Article number: | 001-04-01 |
The SRAM Centerline X 6‑Bolt Disc Brake Rotor integrates a lightweight aluminum spider with a durable stainless‑steel braking surface, ensuring quiet, smooth braking and excellent heat dissipation. The two‑piece design cuts weight without sacrificing sturdiness, and the rounded rotor edges simplify wheel installation and meet UCI standards
Features:
Lightweight, two-piece design
Rounded edges are UCI-compliant and allow for easier wheel installs
Compatible with both road and mountain bike brakes
Diameter | 140mm, 160mm, 180mm |
Color | Black / Silver |
Bolt Material | Steel, Titanium |
Hub Interface | 6 Bolt |
Rotor Type | Centerline 2-Piece |
Lockring | Lockring sold separately |
_____________________: | _________________________ |
Material: | • Aluminum / Stainless / Titanium |
Compatibility: | • 6-Bolt / Centerlock |
Rotor Thickness: | • 1.8 mm |
Includes: | • Rotor / (6) Titanium Bolts |
