Wahoo / Speedplay Pedals
$279.99
$229.99
Article number: 011-04-01
Experience the reinvention of the world's only dual-sided clipless pedal, a collaboration between Speedplay and Wahoo. The re-engineered spindle and pedal body elevate Speedplay pedals. Renowned for unparalleled adjustability, customizable cleat position and float for optimal power output and knee comfort. Wahoo's pedal system excels in stack height, weight, aerodynamics, and cornering clearance, setting a high standard.
  NANO AERO ZERO COMP
 Weight ~168g ~224g ~222g ~232g
 Stack Height 11.5mm (3-hole) / 8.5mm (4-hole) 11.5mm (3-hole) / 8.4mm (4-hole)
 Body Material Carbon Grivory GV-6H Grivory GV-6H Grivory GV-6H
 Spindle Material Titanium Stainless Chromoly
 Spindle Length 53mm 53mm 53 / 56 / 59 / 65 53mm
 Cornering Clearance 39° 37° 39° 39°
 Max Rider Weight 180lbs / 82kg No Restriction No Restriction No Restriction
 Cleats Included Standard Tension Standard Tension Easy Tension Standard Tension
 Release Angle 0° to 15° 0° to 15° 0° to 15° 0° to 15°
 Walkable Cleat Yes Yes Yes Yes
