Woodman Double Chainring Bolts
$25.00
Article number: 012-06-04
Woodman Double Chainring Bolts are a lightweight fastening set for riders who want secure double-chainring mounting without resorting to heavier steel hardware. Built around a traditional bolt-and-sleeved-nut design, they are engineered to balance low weight with the higher clamping strength needed for performance road, gravel, and mountain drivetrains.
A key detail is the use of differential tool interfaces: a smaller T20 Torx on one side and a larger 6 mm hex on the other. According to the current Fair Wheel listing, this layout improves tool engagement while preserving more material around the threaded sections. Each bolt is also marked with its 12 Nm torque rating for easier installation reference.
Fit Note: These are designed for double chainring applications. Fair Wheel’s current page also tags the product to 5 x 110 BCD and 5 x 130 BCD use cases.
 Weight Per Set ~9.5 g
 Tool Fitment T20 Torx / 6 mm Hex
 Torque Rating 12 Nm
 Application Double Chainring
Looking for other lightweight hardware and replacement fasteners? Browse our Bolts category for drivetrain, cockpit, and seating hardware.
For additional drivetrain finishing parts, explore our Chainrings & Parts section.
