Woodman GT2 Seatpost for Brompton Bikes
$125.00
$85.00
* Unit price: $85.00 /
Article number: 012-02-05
Woodman GT2 Seatpost for Brompton Bikes is a lightweight alloy seatpost built specifically for Brompton folding bikes. Made from 6061-T6 aluminum, it is designed to deliver a clean balance of low weight, dependable stiffness, and long-term durability for bikes that are regularly folded, transported, and ridden in mixed urban use.
The anti-slip surface finish helps maintain secure frame interface under repeated use, while the 0 mm offset design keeps saddle position neutral and straightforward. A 7 x 9 mm saddle rail cradle supports modern saddle fitment, making the GT2 a practical upgrade for Brompton riders who want a lighter, more refined replacement than a basic stock post.
Important: The current Fair Wheel page shows a weight mismatch between the body copy and the spec table. The body copy states ~320 g, while the table lists ~349 g. I would verify the correct figure and keep only one value on the final page.
Diameter Length
31.8 mm 600 mm
 Claimed Weight ~349 g
 Minimum Insertion 190 mm
 Setback 0 mm
 Rail Compatibility 7 x 9 mm
 Material 6061-T6 Aluminum
A strong upgrade choice for Brompton riders who want a purpose-built alloy post with cleaner finish, lower weight, and straightforward fit.
