Woodman IT Integrated Setback Seat Mast
| Article number: | 012-02-01 |
Woodman IT Integrated Setback Seat Mast is a lightweight integrated seat mast head built for riders who want precise saddle positioning without adding unnecessary bulk at the top of an ISP frame. Milled from a single billet of 6061-T6 aluminum and paired with premium titanium bolts, it delivers a clean, low-mass solution for performance-focused road and gravel builds.
Its 25 mm setback helps riders achieve a more rearward saddle position for fit refinement, while the cradle-and-yoke clamp supports both carbon and metal rails in round or ovalized formats. With a 26 mm stack height, 10 mm adjustment range, and compatibility across integrated mast diameters from 27.2 mm to 38.3 mm, the IT gives broad fit flexibility for a wide range of ISP frames.
Installation Note: The forward yoke bolt requires a 5.5 mm box-end wrench. Fair Wheel’s current listing states that the wrench and installation instructions are included.
Need the same integrated mast solution with a more neutral saddle position? The Woodman IT Zero Setback Integrated Seat Mast is the direct geometry alternative for riders who want an ISP head with 0 mm offset.
