Alligator I-Link Brake Housing / Cable Kit
| Article number: | 09-04-02 |
Alligator I-Link Brake Housing & Cable Kit is a lightweight segmented brake housing system designed to reduce cable housing weight while maintaining smooth, consistent brake feel. The aluminum link construction works with a continuous polymer liner to reduce friction between the brake cable and housing.
Each kit includes Alligator I-Link brake housing components and PTFE-coated brake cables for road brake systems. Choose the correct fit option for your brake lever type and routing setup, including Shimano/SRAM or Campagnolo and internal or external frame routing.
Compatibility Notes
Select the kit based on your brake lever system and frame routing. Shimano/SRAM and Campagnolo brake cable options are available, with internal-routing versions for frames that require a continuous liner through the frame. Internal kits include liner and end-cap support for cable-stop routing, while standard 5 mm brake housing is supplied for frames without cable stops.
Installation Notes
Confirm your lever type, routing style, and required housing path before cutting. Segmented housing systems depend on proper liner length, clean cable paths, and secure end-cap placement for best brake feel.
For replacement service parts or related cable upgrades, see the Alligator I-Link replacement liner, Alligator Superior Shine 31 Strand Cable, or KCNC Titanium Cables.
