Ashima Ai2 Super Light Rotor
$25.00
Article number: 007-06-02
The Ai2 Super Light is Ashima’s minimalist, single-piece rotor engineered from SUS410 stainless steel with extensive weight-relief cut-outs. Precision laser machining and double-ground braking faces promote parallelism, rapid bed-in, and stable friction. The Ai2 prioritizes low mass for responsive acceleration and reduced rotating weight while preserving consistent stopping on road, gravel, CX, and XC applications. Available in 140 and 160 mm, and supplied with six steel rotor bolts.
Install notes: Degrease rotor, use medium threadlocker on bolt threads, tighten in a star pattern to hub/rotor maker torque spec, and bed-in per caliper manufacturer guidance.
  140 mm 160 mm
 Weight ~64g ~72g
 Material
-Rotor SUS410 Stainless Steel
 Fits 6-bolt (ISO)
 Included (6x) - Steel Rotor Bolts (~12g)
  • Want a two-piece option?
    • See the AiNeon Rotor for alloy-carrier stability in larger sizes.
