Ashima AiRotor Disc Brake Rotor
$30.00
Article number: 007-05-05
The Ashima AI Stainless Steel Rotor is a single-piece, lightweight 6-bolt rotor engineered from high-grade SUS410 stainless steel. Precision machining and large ventilation cut-outs reduce mass and improve heat shedding, while double-ground braking surfaces support parallelism and consistent pad contact. No special pads are required—use with standard organic or metallic compounds. Offered in 140, 160, and 180 mm with verified weights below. with verified weights below; stainless rotor bolts are included.
  • road, gravel, CX, and XC where low mass and predictable braking are prioritized.
  • (For ultra-light alternatives or 2-piece designs, see Ai2 / AiNeon rotors.)
Install notes: Degrease rotor, use medium threadlocker on bolt threads, tighten in a star pattern to hub/rotor maker torque spec, and bed-in per caliper manufacturer guidance.
 Sizes 140 mm 160 mm 180 mm
 Weight ~68g ~85g ~112g
 Material SUS410 Stainless Steel Rotor
 Interface 6-bolt (ISO)
 Pad Compatibility Organic or metallic
 Included Stainless rotor bolts (~13 g)
 Colors Black / Blue / Red - 140 mm / 160 mm
  White - 160 mm / 180 mm
_____________________: _________________________
Material: • Single-piece SUS410 stainless
Compatibility: • 6-Bolt / Centerlock
Rotor Thickness: • 1.8 mm
Includes: • Rotor / Steel Rotor Bolts
