$8.00
Article number: 007-06-06
The Ashima Bottle Cage Bolts provide a lightweight and durable replacement option for securing bottle cages or accessories to standard frame mounts. Precision-machined for consistent fit, these bolts are available in aluminum or steel, offering riders a choice between reduced weight or maximum durability.
Each set includes four bolts, suitable for securing two cages or one cage plus accessory mounts. Standard M5 × 12 mm threading ensures compatibility with most bicycle frames.
  • 7075 aluminum construction for strength and weight savings
  • Sold in pairs (2 bolts) — enough for one cage
  • Standard M5 × 12 mm thread for universal fit
  • Low-profile hex socket heads for a flush install
  • Ideal lightweight replacement for stock hardware
 Weight ~2–3 g (Pair)
 Material 7075 Aluminum
 Quantity 2 Bolts (Pair)
 Thread Size M5 × 12 mm
 Application Bottle Cages / Frame Mounts
Pair these bolts with our selection of our Fair Wheel Bottle Cages for a lightweight hydration solution.
Match your build with our Ashima Aluminum Rotor Bolts for a cohesive anodized hardware setup.
See more finishing hardware in our Lightweight Bolts & Accessories Collection.
