$58.60
Article number: 007-05-01
The Ashima Centerlock Rotor pairs a SUS410 stainless-steel braking ring with your choice of 7075-T6 alloy or stainless-steel carrier (size-dependent). The two-piece construction improves heat stability and rotor trueness, while the Centerlock interface speeds installation and alignment. Available in 140, 160, and 180 mm with verified weights below. Materials and construction match Ashima’s lightweight performance focus seen across Ai2/AiNeon families.
Use cases:
  • road, gravel, CX; choose alloy carrier for lower mass
  • steel carrier for maximum robustness.
  140 mm 160 mm 180 mm
Weight
Alloy Carrier ~96g ~122g
Steel Carrier   ~133g ~161g
Material
SUS410 Stainless Steel Rotor
7075-T6 Aluminum Carrier
Stainless Steel Carrier
_____________________: _________________________
Material: • Rotor / Carrier - Stainless Steel | Carrier - 7075-T6 Aluminum
Compatibility: • Centerlock
Rotor Thickness: • 1.8 mm
Includes: • Rotor
