Ashima Reaction Shift Housing / Cable Set
Article number: | 12-01-02 |
Ashima Reaction shift cable and housing kit. Lighter and smoother than standard cable/housing sets. Each Shifter cable kit includes enough housing for one bike, 2 teflon coated cables, sealing liner and patented fer-flex ferrules. A typical Ashima brake housing setup is on average 30-40 grams lighter than a comparable Shimano/Sram/Campagnolo housing set.
Ashima shift cable housing replaces the heavy steel wire wrap of traditional cables with a light, strong and flexible kevlar jacket. The housing is lined with a PVDF liner for smooth friction-free movement of the cable.
Each kit includes 2 stainless steel shift cables. 19 strands with slick black teflon outer coating giving it a slippery finish.
Each kit comes with Ashimas patented Fer-Flex ferrules. This is a sealed cup and ball ferrule that reduces friction in the lines by allowing the inner to sit at a different angle than the outer ferrule housing for a smoother routing.
Weight | Housing 60g, Cables 26g |
Cable Compatibility | 5mm housing |
Groupset Compatibility | Shimano / SRAM, Campagnolo |
