$94.99
Article number: 005-03-01
Holding a Cane Creek 110 Headset lets you truly appreciate the craftsmanship that goes into this premium version in Cane Creeks lineup. The machining is artful and only bested by the ultralight AER Headset, but the 110-Series has some unique features that greatly improve its lifespan. The double shielded bearings offer an improved lifespan in the harshest environments. The crown race has a double lip seal that seals against the inside of the frame/lower cup as well as the outer race of the bearing. For the External Cup version of the 110 Headset there is a slot machined into the inner face with an o-ring installed in it. Longevity combined with easy user serviceability, and readily available replacement parts make the 110 Headset a perfect choice for any build. If you ride in harsh environments and require your equipment to last, the Cane Creek 110 is the ideal choice.
If you have any questions about these headsets please contact us or check out Cane Creeks S.H.I.S. guide to determine the proper headset for your application.
  Stack / Weight
Headset SHIS Short Tall
 IS 41 Integrated 41 mm 9 mm / ~ 42g 15 mm / ~ 44g
 IS 42 Integrated 42 mm 9 mm / ~ 42g 15 mm / ~ 44g
 ZS 44 Zero Stack 44 mm 8 mm / ~ 53g 15 mm / ~ 60g
