Cane Creek eeSilk + Suspension Seatpost - 35 mm
$319.99
Article number: 005-04-00
The Cane Creek eeSilk+ Suspension Seatpost offers up to 35 mm of smooth suspension travel via a compact parallel‑linkage design, delivering road and gravel riders meaningful compliance without excessive weight. Crafted with forged and machined aluminum linkage arms, stainless steel axles with IGUS bushings, and elastomer‑based damping, the post reduces vibration and harsh edge hits while maintaining consistent saddle position and efficient pedalling. Carbon and alloy versions are available with available diameters of 27.2 mm and 31.6 mm; the stock elastomer (#5 medium) is tunable via five optional elastomers to match rider weight and preference. Up to a 250 lb (113 kg) rider rating ensures wide applicability.
Ideal for endurance road, all‑road, and gravel applications where comfort and control are key, the eeSilk+ integrates the proven suspension linkage of Cane Creek’s previous models into a lighter package.
  Carbon Aluminum
 Weight ~ 345g (27.2 mm) ~ 385g (27.2 mm)
 Length 350 mm 375 mm
 Min / Max Extension 70 mm / 250 mm 70 mm / 275 mm
 Material Carbon / Aluminum / Stainless Aluminum / Stainless Steel
 Offset 12 mm
 Travel 35 mm
 Rider Weight 150 - 210 lb (68-95kg) *Recommended
 Max Rider Weight 250 lbs. (113 kg.)
Elastomer Installed -- Medium
Technical Info
