$319.99
Article number: 005-04-00
 The eeSilk seatpost adds several design improvements for increased lateral stability and now comes with two post options - alloy or carbon and an increased 35mm suspension travel. With a weight of less than 350 grams for the carbon option and a price of $219.99 for the alloy option, the eeSilk post is now a perfect fit for more riders looking to extend their ride.
  Carbon Aluminum
 Weight ~ 345g (27.2 mm) ~ 385g (27.2 mm)
 Length 350 mm 375 mm
 Min / Max Extension 70 mm / 250 mm 70 mm / 275 mm
 Material Carbon / Aluminum / Stainless Aluminum / Stainless Steel
 Offset 12 mm
 Travel 35 mm
 Rider Weight 150 - 210 lb (68-95kg) *Recommended
 Max Rider Weight 250 lbs. (113 kg.)
Elastomer Installed -- Medium
Technical Info
