Carbon-Ti X-CarboRing EVO 4-Bolt Carbon Chainring
$246.00
* Unit price: $225.00 /
Carbon-Ti's "EVO" outer chainrings, boasting thicker carbon fiber plates and precision CNC machining, provide heightened stiffness. Redesigned titanium pins and ramps ensure swift, accurate shifts for electronic and mechanical derailleurs. The 4-arm 110 BCD X-CarboRing, with tooth counts from 50 to 54, suits various cranksets, including Dura-Ace FC-9200/9100/9000, Ultegra FC-8100/8000, SRM Origin 4-arm, and Rotor Power Meter INSpider cranks. Offering broad compatibility with Shimano 11 & 12-speed, SRAM 11-speed, and Campagnolo 11 & 12-speed drivetrains, these chainrings enhance performance.
For the corresponding inner chainring, fitting all 4-bolt 110 BCD cranks, orders can be placed here. However, they aren't compatible with SRAM AXS 12-speed groups. If you use SRAM AXS, opt for X-AXS chainrings with 110 BCD or 107 BCD. Carbon-Ti's D/A 9200 suits current and older Shimano 4-bolt cranks, while D/A 9100 pairs with Shimano 9100 and older 4-bolt cranks, not the new 9200. Elevate your setup with Carbon-Ti's X-CarboRing, ensuring unparalleled performance and style in your cycling experience.
 Material Carbon (body), AL7075-T6 Aluminum (teeth), Titanium (pins)
 BCD 4-Bolt - 110 BCD
 Drivetrain   Compatibility Shimano 11 / 12spd, SRAM 11spd, and Campagnolo 11 / 12spd
 Optimal   Combinations 54t / 40t  |  53t / 39t  |  52t / 36t  |  50t / 34t
 Crank Compatibility Shimano R9200 / 9100 / 9000 / 8100 / 8000 / 6800
  SRM Origin | Rotor INSpider | Campagnolo 11 / 12spd
Weight 54 tooth 53 tooth 52 tooth 50 tooth
R9200 ~114g / ~104g ~97g
R9100 ~115g ~107g ~106g ~99g
