DT Swiss 180 EXP Straight-Pull Disc Rear Hub
$714.90
Article number: 023-06-02
The latest 180 hub generation enhances DT Swiss' top-of-the-line hub. Ratchet EXP system boosts bearing lifetime, stiffness by 15%, and energy transfer with 36 teeth. Tool-free disassembly and lightweight design make maintenance a breeze. Paired with SINC ceramic bearings, these hubs offer unparalleled performance. The hollow-machined ratchets transfer the invested energy directly into acceleration, thanks to the 36 teeth. You have the option to upgrade to a 54-tooth engagement here for improved performance.
WHEEL BUILDING
  Compare
  180 240
  24 hole 28 hole 24 hole 28 hole
 Weight ~187g ~190g ~192g ~196g
 Spoke Holes 24h / 28h  24h / 28h
 Bearings Size Ceramic 6802 / 1526 Stainless
 Axle Standard T/A 12 x 100 T/A 12 x 100
 Brake Interface Centerlock Centerlock
 Freehub Engagement Ratchet EXP 36t Ratchet EXP 36t
  24 hole 28 hole
 Flange Diameter Left 35.7 mm 35.4 mm
 Flange Diameter Right 42.3 mm 41.8 mm
 Center to Left Flange 33.4 mm 33.4 mm
 Center to Right Flange 17.3 mm 17.5 mm
 Spoke Hole Offset L / R 1.4 mm / 0.2 mm 2.0 mm / 0.4 mm
 Spoke Hole Diametere 2.5 mm
