DT Swiss 180 EXP Road Rim Brake Rear Hub
$714.90
Article number: 023-06-02
The latest 180 hub generation enhances DT Swiss' top-of-the-line hub. Ratchet EXP system boosts bearing lifetime, stiffness by 15%, and energy transfer with 36 teeth. Tool-free disassembly and lightweight design make maintenance a breeze. Paired with SINC ceramic bearings, these hubs offer unparalleled performance. The hollow-machined ratchets transfer the invested energy directly into acceleration, thanks to the 36 teeth. You have the option to upgrade to a 54-tooth engagement here for improved performance.
WHEEL BUILDING
  Compare
  180 240
 Weight ~182g ~232g
 Spoke Holes 24h 24h
 Axle Standard 5 x 130 mm 5 x 130 mm
 Bearing Size Ceramic 6802 / 1526 1526 - (2)
 Brake Interface Rim Brake Rim Brake
 Bearing Size Ratchet EXP 36t
--Wheel Building Dimensions--
 Flange Diameter Left 35.7 mm
 Flange Diameter Right 42.3 mm
 Center to Right Flange 33.3 mm
 Center to Left Flange 15.4 mm
 Spoke Hole Offset L / R 1.4 mm / 0.0 mm
 Spoke Hole Diameter 2.5 mm
