DT Swiss 350 J-Bend Boost Disc Rear Hub
Article number: | 11-03-01 |
DT Swiss has redesigned their most popular rear hubs to fit the Boost 148 standard.
With the same design features as the 240s, the DT 350 hub platform offers most of the same performance benefits at a more economical price. With a slight change in production and utilizing key factories overseas, DT has enabled customers to procure their legendary hubs without emptying their wallet. With common size sealed bearings and standard hub flanges these hubs can be serviced by any bike shop or home mechanic with a few basic tools and a bearing press. With the optional upgrade to a 54 tooth ratchet system these hubs offer nearly instant engagement without a sacrifice in durability. Requiring slightly more frequent maintenance than the stock setup the Rapid Drive rings give riders a noticeable performance upgrade without significant sacrifice.
DT Swiss 350 hubs are backed by a 2-year warranty against defects in materials and manufacturing.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheel build.
Weight |
~272g. |
Axle Standard |
12 x 148mm Boost |
Bearing Sizes |
6902 (4) |
Wheelbuilding Dimensions |
Flange Diameter |
46.0 mm |
Center to Left Flange |
36.0 mm |
Center to Right Flange |
23.2 mm |
