$284.90
DT Swiss updates rear hubs for Boost 148, with 240-inspired design for performance. The DT 350 hub combines advantages with affordability, thanks to streamlined production and overseas facilities. Easy servicing with standard bearings and hub flanges. Opt for the 54-tooth ratchet for quick engagement. Rapid Drive rings boost performance with few trade-offs.
WHEEL BUILDING
Trust a skilled wheelbuilder for DT Swiss hub wheels. Please contact us for expert service and rim/spoke advice.
  Centerlock 6-Bolt
 Weight ~249g ~277g
 Bearing Size 6902 - (2)
 Spoke Holes 28 / 32
 Axle Standard 12 x 148mm Boost
 Freehub Body Options Shimano 10/11 / SRAM XD / Micro Spline
 Freehub System 36t SL Ratchet
--Wheel Building Dimensions--
 Flange Diameter Left 47 mm 60 mm
 Flange Diameter Right 47 mm 50.5 mm
 Center to Left Flange 36 mm 36.6 mm
 Center to Right Flange 23.2 mm 23.4 mm
 Spoke Hole Diameter 2.6 mm
