$27.20
Article number: 010-03-05
The DT Swiss Centerlock Adapter allows ISO 6-bolt rotors to be quickly and easily fitted to the splines on a centerlock brake rotor mount. With the lockring's external tool splines, the internal diameter of the adapter is increased, allowing for use on hubs with all common axle standards: quick release, 12mm, 15mm, and 20mm. These high quality adapters are manufactured in Switzerland by DT Swiss.
 Compatibility Road MTB
 Fits Max 160 mm Max 210 mm
 Weight ~31g ~42g
 Hub Type Centerlock
 Max Rotor Size 210 mm
 Rotor Thickness ~1.8 - 2.2 mm
