| Article number: |
ENVE-3-2 |
| Availability: |
In stock
ENVE’s Shimano Di2 Seatpost Battery Grommet allows clean internal integration of a Shimano Di2 seatpost battery within compatible ENVE carbon seatposts. The grommet secures the battery to prevent movement and noise over rough terrain, eliminating the need for zip ties or electrical tape. It protects the battery from vibration and moisture while maintaining a clean, professional installation.
| Seatpost Diameter |
25.4 mm |
27.2 mm |
30.9 / 31.6 mm |
| Weight |
~7.5 g |
~9.1 g |
~16.6 g |
| Compatibility |
ENVE Carbon Seatposts |
Installation Notes
- Designed for Shimano Di2 internal seatpost battery systems.
- Select the correct diameter to match your ENVE seatpost.
- Ensures secure, noise-free battery retention inside the post.
