Far and Near Single Road Chainring Bolts
| Article number: | 018-03-01 |
Far and Near 1x Chainring Bolts are designed specifically for single chainring drivetrain setups, providing a lightweight and secure mounting solution without the need for spacers. Machined from 7075 aluminum, these bolts replace standard double chainring hardware with a shorter, more optimized design for 1x applications.
Available in anodized finishes, they offer both weight savings and a clean, minimal aesthetic for road, gravel, and cyclocross builds. Ideal for modern 1x drivetrains, they ensure proper chainring mounting with reduced hardware complexity.
- 1x drivetrain setups (road, gravel, cyclocross)
- Replacing double chainring bolts with proper single-ring hardware
- Reducing weight and simplifying chainring mounting
- Custom builds with anodized component matching
- Modern narrow-wide chainring installations
Installation Notes
Install using a 4 mm hex wrench. Apply medium-strength threadlocker and tighten to approximately 8 Nm. Ensure the chainring is properly aligned before final torque.
Pairs Well With
- Carbon-Ti Chainrings – optimized for 1x drivetrain setups
- CeramicSpeed OSPW Systems – drivetrain efficiency upgrade
- Abbey 4-Way Tool – precision installation tool
Using dedicated 1x chainring bolts ensures proper clamping, reduced weight, and a cleaner drivetrain setup compared to adapting double chainring hardware.
