FSA K-Wing AGX Handlebar
$336.00
$319.20
Article number: FitWorks
FSA's AGX components shine in Adventure, Gravel, and Cyclocross, and the carbon handlebar, based on K-Wing ergonomics, is no different. Sculpted for comfort in "hoods" and "drops," it prioritizes rider ergonomics. Flared drops enhance stability on rough terrain. Key features include compatibility with ACR and Semi-integrated Cable Routing, reinforcing textured clamping areas, 115mm drop, 76mm reach, 12° outward bend, 10° forward angle, 25mm offset drops, and 5mm rise. Available in various sizes (Ø31.8mm x 400, 420, 440, 460, 480mm), it weighs just 205 grams for the 420mm version. A winning combo of lightweight, stiffness, and compliance for off-road adventures.
Measurements (C - C)
 Width 40 mm 42 mm 44 mm 46 mm 48 mm
Dropouts 449 mm 469 mm 489 mm 509 mm 529 mm
Hoods 403.5 mm 423.5 mm 443.5 mm 463.5 mm 483.5 mm
 Weight ~200g ~205g ~212g ~218g ~226g
 Reach 75.7 mm
 Drop 115 mm
 Outward Bend 12° degrees
 Forward Angle 10° degrees
 Drop Offset 25 mm
 Stem Clamp Diameter 31.8 mm
 Material UD Carbon Monocoque
