HED Belgium R Disc Brake Rim
$175.00
Article number: 5085
Availability: In stock (3)
As the designers of some of the finest alloy rims available, HED's Belgium is one of our top choices for custom wheel builds. As a result of extremely strict manufacturing tolerances and a high level of quality control, HED has produced a series of nearly perfectly round alloy rims that are rivaled by none. With such tight tolerances in place, this allows for finer wheel builds with better spoke tension balance, ensuring longevity. Additional features include a practically imperceptible welded seam and wider profile for maximum durability; each Plus rim is an investment in your bike’s future.
In the wake of rising popularity for wide profile road rims, HED has decided to produce perhaps one of the absolute finest options available. Slightly wider than the venerable C2 rim, the Belgium R is a 25mm wide road tubeless option that guarantees all the positive attributes desired from a wide profile. By widening the rim profile, air volume within the tire is increased, which results in better handling in corners and a more supple ride over rough terrain. If you constantly find yourself on a variety of terrain, be it dirt or paved, the Plus rim from HED assures an ideal ride for years to come.
Wheel Building
Weight 425 grams
Material Aluminum Alloy
Outer Width 25mm
Innder Width 21mm
Depth 24mm
Tire Compatibility 700c
Tubeless Compatible Yes
ERD 593
