KCNC 7075 Front Thru Axle
Article number: | 20-03-04 |
Experience the minimalist allure of KCNC's Low Profile Thru Axles, a sleek alternative to their Indexing and Quick Release counterparts. Shedding grams without compromising strength, these 7075 aluminum axles, with a durable hard anodized finish, guarantee lightweight resilience on rugged rides. Designed for weight-conscious riders, these axles offer a touch of flair with KCNC's signature hues, ensuring an upgrade that merges style and substance. Lighter than OEM axles, they promise durability and a rock-proof design, embodying KCNC's commitment to high-performance, lightweight components for avid cyclists.
Compatibility
KCNC thru axles come in several different options. Please make sure to select the correct axle type to go with your frame. For tool free installation check out KCNC’s Indexing or KCNC's Quick Release thru axle options.
For complete sizing details on all of our thru axles please look HERE.
Model | Interface | Length | Thread Length | Thread Pitch | Weight |
Fox / E-Thru | Flat | 146 mm | 16 mm | 14 x 1.5 mm | ~32g |
Rock Shox | Flat | 148 mm | 11 mm | 15 x 1.5 mm | ~32g |
Fox Boost | Flat | 156 mm | 16 mm | 14 x 1.5 mm | ~34g |
Rock Shox Boost | Flat | 158 mm | 11 mm | 15 x 1.5 mm | ~34g |
Material | 7075 Aluminum | ||||
Hub Compatibility | TA 15 x 100 / TA 15 x 110 | ||||
Tool Fitting | 6 mm Allen | ||||
Recommended Torque | 10Nm |
