KCNC QR Rear Thru Axle
$100.00
$65.00
* Unit price: $65.00 /
Article number: 022-01-03
KCNC QR Rear Thru Axle is a lightweight quick-release style rear thru axle for 12 x 142 mm frames. CNC-machined from 7075 aluminum, it uses KCNC’s hollow axle and cam lever design to reduce weight while keeping wheel installation and removal simple.
Available in versions for Syntace X12 / DT Swiss, Shimano E-Thru, and RockShox Maxle standards, this axle is a practical replacement or upgrade for riders who want a lighter, cleanly machined rear thru axle with tool-free operation.
Compatibility Note: Thru axle fit is frame-specific. Match the axle standard, overall length, thread pitch, thread length, and dropout interface before ordering. A 12 x 142 mm rear hub does not guarantee that every 12 x 142 mm axle standard will fit your frame.
KCNC QR Rear Thru Axle Compatibility
Model Interface Length Pitch Thread Length Weight
DT Swiss / X-12 Tapered 160 mm 12 x 1.0 mm 15 mm ~49 g
Shimano E-Thru Flat 170 mm 12 x 1.5 mm 15 mm ~44 g
RockShox Maxle Flat 172 mm 12 x 1.75 mm 21 mm ~47 g
 Material 7075 Aluminum
 Hub / Frame Spacing Rear 12 x 142 mm Thru Axle
 Lever Type Quick-Release Cam Lever
 Axle Design Hollow Axle
 Recommended Torque 10 Nm
KCNC’s quick-release thru axle design is useful for riders who want tool-free rear wheel removal while still matching the correct 12 x 142 mm thru axle standard for their frame. Confirm your frame manufacturer’s axle dimensions before selecting a replacement.
Need help checking axle fit? Review our thru axle sizing guide, or pair this axle with other KCNC components and compatible wheel components.
