Praxis N/W 1X Direct Mount Road / Gravel / CX Chainring
Article number: | 28-05-04 |
The updated Praxis DM-1X rings bring Narrow/Wide 1x drivetrain performance to road, gravel, and cyclocross bikes. Forged and machined from 7075-T6 aluminum then hard anodized for durability, these direct-mount rings are precisely engineered for optimal chain retention and shifting performance. With options from 36T to 50T, dial in your ideal gearing. Whether you're grinding up steep gravel climbs or railing corners on a tight 'cross course, Praxis DM-1X rings deliver versatile 1x drivetrain simplicity so you can focus on the ride. Engineered for adventure.
Weight | |||||
36t | 40t | 42t | 44t | 48t | 50t |
~94g | ~100g | ~110g | ~151g | ~166g | ~171g |
Chainline | |||||
Road Cranks - 45.5 mm | Gravel Cranks - 48 mm | ||||
Material | |||||
Forged / Machined | 7075-T6 Aluminum | Hard Blk Anodized | |||||
Crank Compatibility | |||||
3-Bolt SRAM Style Direct Mount Cranks | |||||
Chain Compatibility | |||||
10 / 11 /12 Speed Compatible | Shimano / SRAM / KMC | |||||
Recommended Rear Derailleur | |||||
Requires Clutch Type Derailleur Shimano Shadow Plus | SRAM Type 2 | Upper Chain Guide | |||||
Not compatible with Campagnolo 10 / 11 / 12 / 13 Speed chains |
SHIPPING
Due to restrictions from International distributors we are not allowed to ship Praxis products to addresses in the following countries: Australia, Austria, Belgium, Canada, China, Czech Republic, Denmark, Finland, France, Germany, Italy, Japan, Liechtenstein, Luxembourg, Malaysia, Netherlands, New Zealand, Norway, Portugal, Singapore, Slovakia, Spain, South Africa, Sweden, Switzerland, UK.
